How to get volume flow rate of a section?
Old   June 11, 2003, 21:35
Default How to get volume flow rate of a section?
Nyquist
My case is incompressible flow. I get the result by 2 ways.
1. I divided the model into two parts. After finish calculation, I read Mass Flux and put one part in a new cset then use post-> flux sum-> zone.
2. Read velocity and density. Use 'spoint curs' to select the section. Use 'intergrat cset' to get A*VN.
Can somebody tell me what's the difference between these two method? The answers are different. Thank you very much.
Old   September 14, 2003, 00:27
Default Re: How to get volume flow rate of a section?
azmir
They were probably different most likely because the location for "spoint curs" was different from your previous "zone." Try to control (write down) the spoint and snorm.
average volume flow rate carno FLUENT 0 April 12, 2007 06:37
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 06:44
CFX:getting mass flow rate across a cross section allamaprabhu CFX 1 February 14, 2006 12:07
shear rate on a section Stephane bone Siemens 1 January 12, 2005 03:33
mass flow rate at different cross section !! Nyquist Siemens 7 September 15, 2003 12:13
