-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   Importing a CAD file into prostar (http://www.cfd-online.com/Forums/cd-adapco/53482-importing-cad-file-into-prostar.html)
Mahbub September 15, 2003 13:27
Hi, I was trying to import a file from Solid Work that I already saved with IGES extension. But whenever I'm trying to open it I can not find it in the "File Selection" window. Thanks a lot.
Brian September 16, 2003 03:27
Re: Importing a CAD file into prostar
Check the file extension. I can't remember which way around it is, but Prostar searches, by default, for .iges extensions, while your file has a .igs extension. Or the other way around.
Ethan September 16, 2003 15:04
My experience is importing iges into prostar is a nightmare.. You might want to try Proam.. but still.. it's a nightmare! Good Luck!!
Leo September 16, 2003 15:52
Exporting as an stl file might be a better option.
TomK September 16, 2003 16:51
Have you tried ez-surf? It is star-cd's first step for an iges file. While pro-am has a hard time with Pro/E files, an iges file written by Pro/E and run through ez-surf (or pro-surf, depending on the version) will get the iges file into pro-am with no surface errors at all. I was suprised at how well it works.
steve September 20, 2003 15:27
Tom K is right - prosurf (used to be called EZ-surf) handles all CAD surfaces much better than the prostar import does.
