-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   LES tutorial file (http://www.cfd-online.com/Forums/cd-adapco/53483-les-tutorial-file.html)
tomosada September 15, 2003 22:03
LES tutorial file
In the tutorial file directory ,which one can use to practice the LES turbulence model. Thank you for answer me!!
Yacine November 23, 2003 16:17
Re: LES tutorial file
As fare as I know there is no tutorial for LES till now but you can try a channel flow case which should be easy to set up. just generate the 3D grid and use the defaults parameters. There is also a tric in saving the .geom and .prob files that you can find information about in the STAR-CD release documents.
