-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   use table (http://www.cfd-online.com/Forums/cd-adapco/53486-use-table.html)
Moon September 17, 2003 12:24
use table
Hi! all
I want to use table in inlet boundary. So I make a table.
independent variables are x,y,z and dependent variables are u,v,w. (coordinate system is 2)
when I make the problem file(*.prob), the messages pop up the windows.
The error messages are
Error -variable X of table "DATA" REferenced by region 1 is not a valid independent variable. problem write stopped.
Error -variable Y of table "DATA" REferenced by region 1 is not a valid independent variable. problem write stopped.
what is problem?
allan September 17, 2003 17:28
Re: use table
how did you create the table file, did you use prostar or something else?
allan
Moon September 17, 2003 22:38
Re: use table
I used prostar. I creat the table file in prostar.
allan September 18, 2003 02:18
Re: use table
That's unusual that its failed, is your boundary planer? If it is say on a z plane, then you don't need to set the z coordinate, it knows where it is. Can you graph your dependant variables?
Allan
Anton Lyaskin September 18, 2003 02:41
Re: use table
For coordinate system 2 (cylindrical) the names of your independent variables should be R and THETA instead of X and Y. It's a bug in PROSTAR - when creating tables it doesn't account for coordinate systems, but when reading them back - it does.
Moon September 18, 2003 05:56
Re: use table
what can I do for this problem?
Brian September 18, 2003 08:58
Re: use table
Edit the file by hand and change the X and Y to R and THETA?
