Erosion problem
Dear All,
Is there anyone who has the experience in simulating erosion problem by using STAR_CD? I have done all the jobs, including calculating the two-phase flow and use the subroutines for erosion model as well as rebound model to calculated the erosion. But when I finished all of the procedures, all the data of erosion rate, erosion ratio, impact velocity and impact angle are zeros. Can anyone tell me what happened? Ko |
Re: Erosion problem
In the 15th issue of Star-CD newsletter there was a small article on errosion modelling. It was done by Wood Group Pressure Control Ltd, you can try to contact them.
Re: Erosion problem
Sometimes, this indicates that you have some problems with the particule trajectory calculation. Do you check that all particules exit the fluid domain.
