October 10, 2003, 00:51 |
fine mesh ==> coarse mesh
How can I turn the fine mesh into coarse mesh (i. e. I refined some cells by mistake)?
October 10, 2003, 12:12 |
Re: fine mesh ==> coarse mesh
If you refined with the cmrefine command, and you have the appropriate casename.refi file, you can use cmunrefine.
If you used crefine, their is no "undo" option. Assuming you haven't done a save, you can resume your original model file. |
October 10, 2003, 14:09 |
you also use the command crse, but make sure that you the gid you coursen can be coursened by 2x2x2
allan |
October 11, 2003, 01:19 |
Thanks!!
Display Modes | |
Create fine mesh that grows to coarse mesh (Urgent | CZ | FLUENT | 1 | January 3, 2009 10:36 |
Initial condition data file from coarse mesh case | Kushagra | FLUENT | 1 | July 25, 2008 21:53 |
HOW turbulene Grid (avoid too fine or too coarse)? | Toulouser | FLUENT | 1 | February 1, 2007 03:47 |
CFdesign behaviour in coarse and fine mesh | Farhad | Autodesk Simulation CFD | 0 | May 30, 2006 10:10 |
streamfunction from u and v on a coarse mesh | ryoga | Main CFD Forum | 0 | February 1, 2002 18:20 |
