fine mesh ==> coarse mesh
How can I turn the fine mesh into coarse mesh (i. e. I refined some cells by mistake)?
Re: fine mesh ==> coarse mesh
If you refined with the cmrefine command, and you have the appropriate casename.refi file, you can use cmunrefine.
If you used crefine, their is no "undo" option. Assuming you haven't done a save, you can resume your original model file. |
you also use the command crse, but make sure that you the gid you coursen can be coursened by 2x2x2
allan |
Thanks!!
