Home > Forums > CD-adapco
merging .ndt files
Old   October 27, 2003, 01:03
Default merging .ndt files
azmir
Hello!
First, what exactly is contained inside .ndt file and how to post-view the content?
Second, how to merge .ndt files (using Pro-HPC)?
Old   October 27, 2003, 05:37
Default Re: merging .ndt files
vladimir krejci
hi azmir
the file contains normal distances from wall boundaries (for low-reynolds or two-layer models of turbulence) see appenix (c-2) in the user-guide if you want to see what is inside this text file in prostar use get user data within post menu
unfortunately you will have to write some simple script to edit the file into a proper format
because .ndt file contains only one row telling: total_number_of_cells cell_number value cell_number value cell_...
so you need to filter it
the proper form of user data is I'd say
10000lines file
each line consists of cell_number and value
hope it helps
Old   November 2, 2003, 22:30
azmir
Thank you for your response!
I can view the .ndt file but I don't know of what use is that file? I mean, how can it be useful to a CFD user? Secondly, I also found a .bshl file in directories of this model. It is an ASCII file and I couldn't open it and don't know what use is this file or if it is important to begin with.
Lastly, do you know how to merge these files into one big file because I'm using Pro-HPC and it's not clear how to merge .ndt or .bshl in Pro-hpc (in case it is important to merge these files prior to post-processing).
Old   November 3, 2003, 05:56
jimbob
Hi Azmir,
You cannot merge a .ndt file or a .bshl file, and you don't need to either. They contain information which is useful to STAR. For example, the .ndt file contains normal distance from walls, the calculation of which can be time consuming, so to prevent STAR from doing this at the start of every run the information is stored in a file.
In general, see appendix C of the user guide to find out what information files contain.
Old   November 6, 2003, 00:55
azmir
Thanks jimbob!
In my user guide App. C there is no mention of .bshl and hence my previous query. The .bshl cannot be viewed at all (ASCII) and that's why I couldn't help but wonder if I should post-view it in prostar in some way or another. If it's not useful at all to the user (i.e. junk bytes of .ndt side-effect), I will just delete it.
If the .ndt is only useful for STAR and not for the user, then I should just delete the thing. Or, should I take a second look at it for a deeper analysis?
Old   November 6, 2003, 05:42
matej forman
What is your problem, Azmir?
Just forget it and delete the files you do not need!
matej
Old   November 7, 2003, 22:59
azmir
Woo! Pardon me for double-checking and asking for 2nd opinion! Thousand apologees!
Thread Tools
Trackbacks are On
Merging volumes??? Kiran FLUENT 4 May 18, 2006 04:46
Help vortex merging bin FLUENT 0 March 8, 2005 20:06
Merging and Uniting Theju FLUENT 0 February 28, 2002 07:10
merging mesh files santosh FLUENT 1 August 1, 2001 09:27
Merging .msh files in TGrid Raza Mirza FLUENT 2 January 18, 2001 19:09
