Home > Forums > CD-adapco
Permeable baffles
Old   October 29, 2003, 03:14
Default Permeable baffles
m-hack
Hey !
Dealing with a flow in a filter kind of domain, I use permeable baffles to completely separate two regions. There should be a certain pressure drop across the baffles, which I know from experimental data. If I calculate with very low values of Ares and Bres (pressure drop not sensible), I get good solutions. Increasing the values of Ares and Bres, I get more and more of Warning #038, which is
UNNORMALIZED RESIDUAL CANNOT BE REDUCED TO 1.0000000E-6 IN EQN: PCOR.
I guess thats the pressure correction equation. Strange is, that in a special range of Ares and Bres, the warnings appear not every iterations, so that some of them will be used to update the field.
My questions are:
- What is exactly happening, or not happening in the iterations with that warning.
- Is there a chance to modify that value of delta = 1.0E-6 for some iterations.
- Do you see a different way of solving that problem
Thanks in advance,
Marc
Thread Tools
Trackbacks are On
Permeable wall BC billy OpenFOAM Pre-Processing 7 August 27, 2009 02:05
Permeable wall billy OpenFOAM Running, Solving & CFD 0 August 29, 2006 18:11
Pipe flow with permeable walls Malama, Bwalya Main CFD Forum 2 August 29, 2001 11:15
permeable wall peter.zhao Main CFD Forum 0 October 23, 2000 08:06
permeable wall Sebastien DANIEL FLUENT 5 July 27, 2000 02:31
