November 17, 2003, 02:18 |
Extracting information on a particle track
Hi!
I would like to get the temperature in each cell that a particle track passes through. Is that possible? Regards Bo |
November 19, 2003, 07:20 |
Re: Extracting information on a particle track
Hi Bo,
Yes it is. The variable idc(idr) gives you the cell number a particle is in. You can print these data from the cell number. If idc.eq.0 the particle is stuck in the domain, If idc.lt.0 it has left the domain. Michiel This was sent to mee as an example in POSDAT.f by starcd COMMON /C33001/ IDC C --- DROPLET DATA OPEN (UNIT=100,FILE='domain.out') OPEN (UNIT=101,FILE='evap.out') OPEN (UNIT=102,FILE='stuck.out') REWIND (100) REWIND (101) REWIND (102) MASSWO = 0.0 HEATWO = 0.0 DO IDR=1,NDR C --- DROPLET (IDR) IS LOCATED IN CELL (IC) IC=IDC(IDR) MASFRA = DRMAIC(IDR,1)/DRM(IDR) IF (IC.GT.0) THEN WRITE (100,911) IDR,IDT(IDR),DRD(IDR),DRM(IDR),DRT(IDR),MASFRA ELSE IF (IC.EQ.0) THEN WRITE (101,911) IDR,IDT(IDR),DRD(IDR),DRM(IDR),DRT(IDR),MASFRA ELSE WRITE (102,911) IDR,IDT(IDR),DRD(IDR),DRM(IDR),DRT(IDR),MASFRA ENDIF MASSWO = DRMAIC(IDR,1) + MASSWO HEATWO = DRT(IDR)* &(4181.72*DRMAIC(IDR,1)+1750*(DRM(IDR)-DRMAIC(IDR,1)))+HEATWO ENDDO CLOSE (100) CLOSE (101) CLOSE (102) |
Particle Track | Domenico | FLUENT | 2 | February 19, 2007 18:56 |
Particle track | James Bewley | CFX | 0 | April 28, 2006 06:04 |
Particle track files | Sankalp | CFX | 1 | August 25, 2004 23:25 |
Particle Track | Zahir | FLUENT | 16 | March 31, 2002 00:29 |
Particle track code | Newbie | Main CFD Forum | 5 | January 22, 2002 08:00 |
