Home > Forums > CD-adapco
BC problem
Old   November 19, 2003, 04:41
Default BC problem
newone
Hi Experts, I am solving a problem involving convergent divergent nozzle. I am employing pressure BC at both ends. Now I have two problems. 1. After post processing I am seeing the Pstat greater (around double) than what I have applied as BC at inlet as well as at outlet. 2. I want to apply only presure at outlet and temperature to be calculated by code. But StarCd wants temperature also at pressure BC. How to do this? Help. -
Old   November 21, 2003, 00:58
Default Re: BC problem
Nyquist
Answer No.1 question. The pressure in STAR-CD is relative pressure. If the environment(or inlet) pressure is 1atm, then you have to set the referance pressure 1atm and in inlet BC set 0atm.
Old   November 21, 2003, 14:22
Brian
Answer to Question 2:
True, you have to specify temperature at pressure boundaries. But this temperature is only used if the flow at the boundary is INTO the domain. If the flow is out of the domain, the temperature is extrapolated from the interior, in the same was as on outlet boundaries.
Same goes for other scalar quantities at pressure boundaries, like TE and ED.
Old   November 24, 2003, 04:14
Daria
If scalar quantities are extrapolated from the interior by default, what means switch ZERO GRAD for scalar quantities TE,ED,T?
Thread Tools
Trackbacks are On
VOF diffuse problem on two fluids problem Fang Jin FLUENT 5 February 17, 2011 06:38
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 10:37
Problem in cavity flow problem saad Main CFD Forum 4 November 1, 2007 08:45
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
problem in solving "wave generation" problem san FLUENT 2 April 3, 2006 23:37
