Subroutine and cell number
Old   November 27, 2003, 14:11
Default Subroutine and cell number
Celia
Hi all,
I am using some subroutines to solve for a scalar transport equation. I am using NCMAX, -NBMAX kind of namings to dimension my paramaters. The program works fine when the cells numbers are relatively small but if I have a lot of cells, ie 125000 then I get "segmentation faults"...? Does anyone have any idea why is this?
Best regards
Old   November 28, 2003, 04:04
Default Re: Subroutine and cell number
Richard
Are you defining your own arrays which are dimensioned using the parameters NCMAX and NBMAX? If so, you need to include the line
include '../parm.inc'
in the header of your subroutine, as this is where those parameters come from.
Old   November 28, 2003, 11:38
Celia
I have defined the above, without the parm.inc you cannot define any parameter. As I mentioned the program works for small mesh size, the problem only occurs when I refine the mesh.
Old   November 29, 2003, 06:14
Ulf
Hi, I have experienced similar problems as you. I got the tip to put my variables into common blocks, e.g.
COMMON/ULFSCOMMON/var1(NCMAX),var2(NCMAX)
Have you tried this?
Regards, ulf
Old   December 1, 2003, 08:16
alex
If you are getting a segmentation fault that means there is something wrong with your array declarations. I wouldn't move them into common blocks, because chances are they will still be wrong. The reason why you only get the problem with large cases is because you are writing lots of information to the wrong place, as opposed to little information to the wrong place, which fortran lets you get away with.
Try: Using a debugger
Old   December 1, 2003, 08:19
alex
or compiling on different platforms failing that, you are left deleting bits of code until you work out which one causes the problem.
Good luck! Declaration errors can often be hard to find.
Old   December 1, 2003, 09:14
Steve
I have to disagree with Alex. Large local Fortran arrays may blow the available stack memory. The answer is to force static storage and Fortran's way to do this is to use either COMMON storage or the SAVE keyword.
Old   December 1, 2003, 09:19
Celia
I actually tried the elimination process and have managed to find a particular area of the code which is causing the trouble. I have been using common blocks to declare my arrays which I have dimensioned using NCMAX etc etc
Thanks for all the helps
How to use the other cell in subroutine? Rich Siemens 1 October 2, 2004 05:44
How to get index of a cell by user subroutine? windhair CFX 1 November 19, 2003 10:30
Cell Reynouds Number MissNancy FLUENT 0 December 1, 2002 17:50
Adjacent cell number Jing Siemens 5 October 21, 2002 06:29
May I use global coordinate of cell centers in subroutine Posdat H. Shen Siemens 4 March 29, 2000 09:20
