Not running
Old   December 18, 2003, 15:18
Default Not running
Mahbub
My computation is not running. It's giving me the following message. Please help me regarding this. Thanks.
"" Warning - Server not running, no information sent to starwatch. &&&& ---- ----------- ---------------------- ------------------ --------------------- -----------------
Calculation terminated - job stopped by user intervention "
Old   December 18, 2003, 16:44
Default Re: Not running
Joel
the server not running no info sent to starwatch is fairly insignificant, it just means that the residual and monitoring information server is not running so that the graphical interface (starwatch) will not be able to pick and view your data, not that important as starwatch is a pile of garbage anyways and i gave up trying to run it years ago. As for the job stopped by user intervention that is something else. Which version of star are you using and on what operating system, also is the run transient or ss?
Old   December 18, 2003, 21:15
Joern Beilke
You created a file "ABORT" in your directory which tells star to correctly stop the calculation after this iteration. So just delte this file. If it is a hpc job type "prohpc abort clear".
Old   December 18, 2003, 22:15
Mahbub
Thanks. My version is 3.150A (build 522 ).
Old   December 18, 2003, 22:22
Mahbub
Yes , I deleted the file "abort" and it's running now. Thank you so much. Would you please tell me how these files have been created?
Old   December 19, 2003, 09:33
Michiel
These files can be sen manually by using 'touch ABORT' but are also used by star if u abort using the interactive (GUI) mode.
Running in patch when your license is running out Andrew CFX 2 August 9, 2007 13:48
Running a *.cas on many PC ? Cyril FLUENT 0 February 15, 2006 10:05
Running HPC Shazlan Siemens 1 April 8, 2005 13:34
Running CFX on a cluster jvk CFX 9 September 19, 2002 22:22
Anyone running under XP? Karl FLUENT 1 June 4, 2002 22:28
