Linux and windows codes giving different results
Old   January 6, 2004, 08:26
Default Linux and windows codes giving different results
Joel
i am currently running a fairly big transient problem, initially on windows (v3.150a) and the simulation is progressing well if a little slow (courant numbers, piso correctors etc etc all look good) due to the time aspect i decided to run it on a far more powerfull linux machine but for some reason the results i am getting are totally different even though the model is exactly the same, any ideas?
Old   January 6, 2004, 17:30
Default Re: Linux and windows codes giving different resul
steve
Are you running the same patch version of STAR on both systems? You may have a bug correction in one that has not been added to the other.
Old   January 7, 2004, 03:51
Frederik
Maybe the REAL (or DOUBLE) values are represented with different precisions on the two platforms? This would lead to different solutions if rounding-errors play a role.
Old   January 7, 2004, 09:15
steve
With any platform (Windows, Linux, whatever) the user can decide to work in single precision or double. Single precision on Windows is the same as single on any other platform and same goes for double. Unless you actually picked single precision on one and double on the other, then that's not why the answers are different.
Slip boundary condition giving strange results hemph OpenFOAM Running, Solving & CFD 3 January 18, 2007 05:15
problems of running SGI codes in windows baal Main CFD Forum 1 August 16, 2005 22:16
.cas .dat Windows vs Linux K. Jagus FLUENT 2 August 9, 2005 13:58
CFX codes in Linux (again). cfd guy CFX 11 February 23, 2002 23:50
fortran codes in windows? Thorsten Main CFD Forum 0 September 24, 1998 07:51
