Multi-Airfoil simulation
Old   January 10, 2004, 19:25
Default Multi-Airfoil simulation
ze
Hi
I have some problems in deal with the stall in a multi airfoil simulation with STAR-CD.
I have cells enough and I have used several different turbulence models as well as different conditions for turbulence at far field.
Have anyone some experience with this subject?
I get good results of CL versus alpha for all alpha range except near stall where the lift continues increasing.
Thanks
ze
Old   January 14, 2004, 16:39
Default Re: Multi-Airfoil simulation
James Date
Hi
As you will find if you read a few texts on RANS solvers and their application to Aerofoil flows, this Phenomena is very common. Basically the turbulence model has difficulty in predicting the point of seperation on the aerofoil. Have a read of Wilcox - Turbulence Modelling, this should explain to you exactly what is happening.
Regards James
Multi-element airfoil analysis CFD Rookie Main CFD Forum 12 November 17, 2016 06:07
multi-element airfoil K Anandhanarayanan Main CFD Forum 1 November 12, 2002 00:46
Looking for :Multi-element airfoil simulation Larry Main CFD Forum 0 February 8, 2001 10:14
Multi Element Airfoil J.Dumas Main CFD Forum 2 May 13, 2000 07:24
Multi-element Airfoil Karthikeyan D Main CFD Forum 0 October 7, 1999 04:19
