January 15, 2004, 07:03 |
Passive Scalars
If you define a passive scalar, e.g. scalar(x) and it is to be calculated in any subroutine via a variable 'y'. How do you define that you want the value of y to be scalar(x). So after doing this you can then post process it? I'll appreciate any help, thanks |
January 15, 2004, 08:23 |
Re: Passive Scalars
You can define the scalar value e.g. in the sorsca.f subroutine.
You can write if(IS.EQ.xx)then where xx is the defined passive scalar. Then you can write S1P=Large_number(like 1E+25) times "y" S2P=Large_number After this, the scalar xx has the value "y". |
January 15, 2004, 09:27 |
Re: Passive Scalars
Not sure I follow Ossi's example. I would use the subroutine "scalfn". In scalfn, do the following;
if (is.eq.x) then C where x is the scalar number phi = y end if This routine is called for every cell and will put the value "y" into scalar "x", which can be post processed in prostar by; load,, getc conc x |
Display Modes | |
Passive scalars and Star-CCM+ | Tim | Siemens | 1 | May 19, 2008 12:04 |
star-ccm+ and passive scalars | tomy | Siemens | 3 | August 21, 2007 16:15 |
gradients of passive scalars | Ulle | Siemens | 1 | July 10, 2005 13:24 |
passive scalars | CMB | Siemens | 2 | February 16, 2004 10:46 |
passive scalars | CMB | Siemens | 0 | December 10, 2003 07:14 |
