LES-D
Old   January 18, 2004, 09:44
Default LES-D
bastide alain
Where can i find a LES Dynamic (lilly) subroutine ????
Yours
A.B.
Old   January 19, 2004, 14:06
Default Re: LES-D
Yacine
is there any?
Old   January 21, 2004, 08:56
Default Re: LES-D
Rainer
Look in the release notes. Maybe it is only beta-status, but you can use it.
Regards
Rainer
Old   January 21, 2004, 09:12
Default Re: LES-D
alain bastide
Nothing in release notes for this model.
Adapco said to me :
== impossible to change viscosity for each momentum equation !!!!
== impossible to now which momentum equation is treated
== impossible to code a Smagorinsky model to test
== we can only add source terms !!!
== This code is tooooooooo CLOSED Not enough OPENED
Now i want to use FLUENT !!!
Old   January 21, 2004, 13:40
Default Re: LES-D
Yacine
It is possible if you want to impliment it yourself by using user defined soubroutine for turbulent viscosity. The trouble by finding the boudries like periodic, walls etc..... Maybe some one in here can help you with that.
