Grid does'nt move!?
Old   February 12, 2004, 04:13
Default Grid does'nt move!?
Sabe
Hi, Problem description: I do want to solve a transient problem with a rotating grid. Therefor, I defined a ASI in a .MAC file, that is executed before the coputation. When I test the event using the EVPREP, it works. The comiling with pmovlink worked without problems and the computation was successful as well. BUT when it comes to check the transient file, the grid did not move, explaining the weird results I obtained! How can that be? With regards, SaBe
Old   February 12, 2004, 05:21
Default Re: Grid does'nt move!?
Jörn Beilke
1) evfi conn
2) load ,, or trload ,,
if you use the gui then there is a button with "static grid/moving grid"
when using the command line the moving grid is on by default
if you forget to connect the event file you can use "getv coor" to get the new vertex positions.
Old   February 12, 2004, 06:49
Sabe
Dear Jörn Beilke, I forgot to say, that the problems where at the post transient file, that means everything works well, the evn file is created, the evt also, the pstt is written, but the grid did not moving during the computation, although the testing before starting the computation of the events and moving grids was successfull! regards, SaBe
Old   February 13, 2004, 05:32
Thomas
a long time ago, that i did moving grid problems, but i rember there is a file (pmov.out?) where all commands from prostar-batch are listed. have a look at this file!
regards,
thomas
Old   February 13, 2004, 05:50
john
just another possibility- (This is applicable only when mesh is uniform and especially rotating mesh). If everything is fine, you may be moving the mesh such that next node is getting moved to the successive nonmoving node. This way mesh will appear as not moving. generally moving distance should be kept less that the half of the distance between two successive nonmoving nodes which are getting attached. If it is more than half the distance mesh will appear moving in opposite direction. Hope you understand what I am saying. Please check. regards
Move particle in UDF Henrik FLUENT 5 July 29, 2008 10:55
how to move a set of vertex cthsieh Siemens 2 September 5, 2007 20:18
Turn and move Coord0 Aloise CFX 1 December 18, 2006 12:01
Making something move, not the air Cyril FLUENT 2 January 30, 2006 07:40
CFD Online Server Move Jonas Larsson Main CFD Forum 0 January 15, 2005 07:42
