Home > Forums > CD-adapco
COMET: fluid-solid interaction
Old   January 26, 2004, 13:49
Default COMET: fluid-solid interaction
Mauro Malve
Hallo! I am a phD Student of the University of Karlsruhe. I am trying to perform a Fluid-solid interaction simulation of a valve inside a water duct. The valve is made of rubber. the coupling actually works, and the valve move hiself, but unfortunately only with small deformations. How can I get large deformations of the mesh? As the mesh moves hiself more than two single cells, the geometry break down. and the simulation can not keep on running. I am using the VSMO command, and of course, MOVGR. But it seemed it does not work as it should. Can you help me in anyway? I am looking forward to hear from you. Best regards, Mauro Malve
Old   January 28, 2004, 04:16
Default Re: COMET: fluid-solid interaction
F.K.
Hello Mauro,
I 've one question regarding your work. You have mentioned that the deformation of rubber is small. Is COMET able to handle rubber (highly non linear)??
Reg.
Old   January 28, 2004, 05:04
Torsten Schenkel
Hallo F.K.,
Same group here, don't be puzzled by a third party chiming in.
No, I don't think so. At least not out of the box. What we are interested in at the moment is the mesh dynamics.
Our application will be even more non linear, actually, but without sufficient mesh deformation and dynamics, we won't even get that far
Torsten
Thread Tools
Trackbacks are On
flotran fluid solid interaction Rishab Mahajan Main CFD Forum 0 December 24, 2005 01:26
Fluid Solid Interaction - divergence bebes CFX 1 May 5, 2005 18:46
FLUId-SoliD InteRACtion !!! any suggetion SAM Main CFD Forum 1 February 7, 2005 21:08
FLUId-SoliD InteRACtion !!! any suggetion SAM Main CFD Forum 0 February 6, 2005 07:42
FLUId-SoliD InteRACtion !!! any suggetion SAM Main CFD Forum 0 February 5, 2005 03:43
