February 22, 2004, 21:33 |
A problem in valve analysis
There is a case for valve analysis .the detail conditions are as follows: (1)spool is tetra mesh and valve sleeve is hexa mesh. (2)spool move 3 mm relatively to sleeve at a speed of 1 mm/s (3)using moving mesh in analysis
I have some puzzles about this case: (1) shall I use ASI method ? (2) can spool be moved by "case.cgrd" through the event step ? (3) shall I couple the spool and sleeve in the events appendix: spool(»¬·§·§Ð¾) sleeve(·§Ì×) |
February 22, 2004, 21:41 |
Re: A problem in valve analysis
I especially want to know (3) : shall I couple the spool and sleeve in the events when using ASI method
gap between valve stem valve | kantharao | Siemens | 0 | September 2, 2008 07:19 |
Globe Valve Aeroacoustic Analysis | Mohammad Kordi | FLUENT | 0 | June 2, 2008 04:18 |
Pressure drop of valve with valve opening of 30% | elogesh | Main CFD Forum | 2 | January 5, 2007 12:30 |
Valve seal problem! Urgent | songxguan | Main CFD Forum | 0 | May 11, 2006 22:04 |
Flow measurement around intake valve pressure condition problem | fedegavo | OpenFOAM Running, Solving & CFD | 1 | January 20, 2006 13:06 |
