negative density
Old   March 4, 2004, 21:12
Default negative density
Jane
Dear evryone
my problem involves the scalar and mass,heat source, when i consider the material is hydrogen and initial value of scalar H2 in this material is 1.0, and use MARS to calculate it, then after 11 iterations. it stops, error is there are negative density at more than 100 cells. but if i set the material is Nitrogen and initial value of H2 is 0.0187, then that is ok. so what do result in it? can anyone tell me?
thank you! ragards jane
Old   March 5, 2004, 02:53
Default Re: negative density
roadracer
If it is a stationary calculation have you tried to lower urf for density,scalars and velocity, at least for the first 50-100 iterates? I suggest you to use CD 0.01 as differencing scheme for density, at least for the initial iterates.
Old   March 5, 2004, 06:09
John
I don't know the detail of your simulation, but the denisty of pure H2 is at least one magnitude smaller that the normal air. So it's easier for density to get very small and hit the problem you have. Maybe you should give more detail of your case.
Old   March 8, 2004, 10:37
Frederik
see also the discussion further down:
http://www.cfd-online.com/Forum/starcd.cgi?read=4054
Old   March 9, 2004, 21:01
Jane
thank you every body! i got it
have a nice day! jane
negative density novice Siemens 1 March 15, 2005 09:27
Negative density Ricky Siemens 6 June 23, 2004 09:48
Negative density Miriam Siemens 0 May 10, 2002 04:21
Negative Density Sangwon Kim Siemens 20 May 8, 2001 08:49
NEGATIVE DENSITY M. R. JAHANNAMA Main CFD Forum 8 September 29, 1999 23:59
