heat transfer
Old   March 16, 2004, 05:37
Default heat transfer
Peter
I'm doing a two-layer simulation of a convective heat transfer problem. But the htran values are calculated very high (about 1000 W/m^2K), although my y+ values are smaller than 1. Hcoef looks fine (about 25W/m^2K). Is htran only calculated for models including wall functions? I have a similar problem with a low-Re-tubulence model.
Thanks in advance, Peter
Old   March 16, 2004, 06:39
Default Re: heat transfer
marco
Hallo Peter!
If you have a look at the definition of HTRAN you see that it uses as reference temperature the fluid temperature in the wall nearest layer. Of course this value is very near to the wall temperature itself when you have very small cells (for example with a mesh for a 2-Layers or a low Re calculation). To compare the STAR results with HTC from the literature you have to use HCOEF and use a suitable TBULK. You can use the OPERATE command to define it properly .
Marco
Forced convection heat transfer in heat sink Sidy FLUENT 1 October 18, 2008 03:27
flow/heat transfer through heat sink (with fins)? Pei-Ying Hsieh Main CFD Forum 1 January 26, 2008 06:33
HEAT-TRANSFER & EXCHANGE HEAT MODEL Problems Jordi FLUENT 1 March 31, 2006 10:30
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 05:09
