how do i know ICONV is either 1 or 2 ?
Old   March 30, 2004, 12:44
Default how do i know ICONV is either 1 or 2 ?
mspark
Hi
ICONV is a conversion parameter: 1 for T->H, 2 for H->T inputting to COTEET. How do i know ICONV is either 1 or 2 ?
Old   March 31, 2004, 03:16
Default Re: how do i know ICONV is either 1 or 2 ?
Richard
IF (ICONV.EQ.1) THEN ... ELSE IF (ICONV.EQ.2) THEN ... END IF
Old   March 31, 2004, 05:55
Default Re: how
mspark
Thanks for repl. however, i know IF statement below. what i want to know is when ICONV is either 1 or 2.
Old   April 1, 2004, 03:14
Default Re: how
Richard
I don't think you need to know exactly when STAR calls COTEET or why, it is enough to know that ICONV=1 means you need to return the H for the given T, and ICONV=2 means T for the given H.
But I guess that, for example, boundary conditions are specified as temperatures, but STAR needs H for the enthalpy equation. Hence after boundary conditions are defined there would be calls to COTEET with ICONV=1. On the other hand, properties may be functions of T so STAR will need to convert H to T before calculating properties.
Old   April 1, 2004, 05:34
Default Re: how
mspark
Hi Richard.
thank you for your opinion. let me try to find out what factor makes ICONV be either 1 or 2.
Best Regard.
mspark
