error in temperature display
Old   March 30, 2004, 02:47
Default error in temperature display
mspark
Hi all I have a problem. what makes it like the picture ?
Old   March 30, 2004, 02:48
Default picture
mspark
<img src=http://cafe81.daum.net/_c21_/pds_down_hdn?grpid=T7Xj&fldid=_album&dataid=7&grpc ode=staruser&realfile=error1.jpg>
Old   March 30, 2004, 02:53
Default picture again
mspark
Old   March 30, 2004, 06:36
Default Re: picture again
Brian
The temperature is constant at 5000K. What you are seeing is colours based on the round-off error around that number.
For some reason, the temperature field has not been solved. Possible reasons are that the solution of temperature has been switched off, or the boundary conditions lead to a constant temperature at steady state.
Old   March 30, 2004, 07:45
didi
By the way I think it is not possible to solve airflow with 5000 K or more with a "standard" cfd -code. Under these circumstances air is not neutral anymore.
Old   March 30, 2004, 10:52
Default Re: thanks for reply :)
mspark
I am trying to find what is going on...
error x display Phil Siemens 2 January 3, 2007 17:21
Display gives error João Fernandes FLUENT 0 July 19, 2006 16:50
display filled contour of temperature gradient Frederik FLUENT 4 August 23, 2005 05:42
display error davis FLUENT 1 February 2, 2005 01:53
Display Error Pat FLUENT 2 June 16, 2003 10:30
