March 30, 2004, 02:47 |
error in temperature display
Hi all I have a problem. what makes it like the picture ?
March 30, 2004, 02:48 |
<img src=http://cafe81.daum.net/_c21_/pds_down_hdn?grpid=T7Xj&fldid=_album&dataid=7&grpc ode=staruser&realfile=error1.jpg>
March 30, 2004, 02:53 |
picture again
March 30, 2004, 06:36 |
Re: picture again
The temperature is constant at 5000K. What you are seeing is colours based on the round-off error around that number.
For some reason, the temperature field has not been solved. Possible reasons are that the solution of temperature has been switched off, or the boundary conditions lead to a constant temperature at steady state. |
March 30, 2004, 07:45 |
Re: picture again
By the way I think it is not possible to solve airflow with 5000 K or more with a "standard" cfd -code. Under these circumstances air is not neutral anymore.
March 30, 2004, 10:52 |
Re: thanks for reply :)
I am trying to find what is going on...
error x display | Phil | Siemens | 2 | January 3, 2007 17:21 |
Display gives error | João Fernandes | FLUENT | 0 | July 19, 2006 16:50 |
display filled contour of temperature gradient | Frederik | FLUENT | 4 | August 23, 2005 05:42 |
display error | davis | FLUENT | 1 | February 2, 2005 01:53 |
Display Error | Pat | FLUENT | 2 | June 16, 2003 10:30 |
