April 6, 2004, 02:19 |
Creating multi-block mesh
I need detailed information about the right strategy of creating multi-block meshes. For example, can one block be created inside the other? if a block can (or should) be deleted after generating a mesh? is it oligatory to create splines if case geometry is simple? is there any way to connect blocks and if this should be done? In short any information on this issue will be appreciated. Regards, Julie |
April 6, 2004, 17:06 |
Re: Creating multi-block mesh
Definitely not. This would create an overlapping mesh which is currently not allowed. > if a block can (or should) be deleted after generating a mesh? Yes it can, but there is no need. Blocks are like construction lines - Prostar knows about them, but the geometry passed to Starsolver contains no information about blocks. > is it obligatory to create splines if case geometry is simple? No. Where there is no spline along the edge of a block, a straight line will be used. > is there any way to connect blocks and if this should be done? Absolutely. Until blocks (or more accurately, the cells created by blocks) are connected together by VMERG or couples, the two meshes are not connected and no flow can take place from one to another. |
Display Modes | |
Multi-block structured GAMBIT mesh help | siw | FLUENT | 0 | December 4, 2008 07:10 |
Multi block geometry | Samir | FLUENT | 0 | January 14, 2005 16:55 |
looking for 2D block/multi-block grid generator | phsieh | Main CFD Forum | 0 | October 29, 2003 09:07 |
Multi-block | Arthur | Main CFD Forum | 9 | May 27, 2002 06:44 |
Multi-block | young min, Sohn | Main CFD Forum | 2 | June 2, 2000 10:56 |
