Home > Forums > CD-adapco
couples issue
Old   April 16, 2004, 02:49
Default couples issue
carno
Hi there,
I want to create couples in fluid and solid cells. The problem here is that there is some partial overlapping at some cells. So the couple check gives error messages (partial overlapping) while writing geometry file. I have checked other checks independantly and all are ok. Is it ok if I write geometry file without check?
Kindly guide if anybody faced similar problem.
- Thanks
Old   April 16, 2004, 02:58
Default Re: couples issue
thomas
well, as far as i know, partial boundaries between fluids and solids are not permitted.
if you run the case (if it is possible) then have a look at flow field around these corner. i would expect some unexpected behaviour.
Thread Tools
Trackbacks are On
Cell Couples in CCM+ norbinou CD-adapco 4 September 10, 2007 10:00
When we need to define Couples! Mehdi CD-adapco 2 March 24, 2006 00:15
about couples bv CD-adapco 1 July 24, 2005 07:05
Boundary Couples ale CD-adapco 0 January 26, 2004 06:09
couples or not couples... giosue CD-adapco 5 March 1, 2003 01:11
