Home > Forums > CD-adapco
Psot register data
Old   April 21, 2004, 00:30
Default Psot register data
Prabodh
Is there any way of writing the data in the post register to a file.
Prabodh
Old   April 21, 2004, 02:29
Default Re: Psot register data
carno
run following commands
ofile,star.out <or any your name> print,all <or cset> close star.out
u will find star.out text file in the same directory.
Old   April 21, 2004, 07:03
Prabodh
hi carno! the command does create an output file like you mentioned. But its a blank file. thanks, prabodh
Old   April 21, 2004, 07:49
Jörn Beilke
once again:
ofile "test.out"
print cset
ofile ,,
close "test.out"
now have a look at the file
Old   April 21, 2004, 08:29
Prabodh
hi Carno! thanks. i was able to write the data into the .out file. but the problem is it writes the data for all cells in the file. is there any way you can write the data for the cell set into the file.
Prabodh
Old   April 22, 2004, 01:39
carno
use
print cset command instead of print
Old   April 22, 2004, 01:42
Prabodh
It works. Thanks Jorn!
Prabodh
Old   April 22, 2004, 07:36
Leo
You can also use the "savu" command (save user data). Type
help savu
on the command line for more info.
Old   April 23, 2004, 01:48
carno
thanks leo. This was new useful command for me.
Thread Tools
Trackbacks are On
Plotting a register data Julie Polyakh CD-adapco 5 April 26, 2004 09:14
How to get data out from register? leo CD-adapco 1 May 2, 2003 08:16
Saving graph register data into a file Julie Polyakh CD-adapco 1 January 27, 2003 21:35
post register Astrid Hostrup CD-adapco 1 July 31, 2000 08:11
