Plotting a register data
Old   April 23, 2004, 02:37
Default Plotting a register data
Julie Polyakh
How do I plot calculated scalar data from register 6, for example?
Regards,
Julie
Old   April 23, 2004, 04:28
Default Re: Plotting a register data
alex
In short, you can't: you have to move it to register 4 first (or registers 1,2 and 3 if it is vector data).
You can move data around from one register to another by using the "oper" command. e.g. oper copy 6 4 will copy the information in register 6 to 4. Data in 4 can then be plotted as a contour.
You can access the GUI version of this command by going to "Lists > Post Registers ... > Operate ..."
Old   April 23, 2004, 08:27
Julie Polyakh
Ok. And how do I plot it from the register 4?
Julie
Old   April 23, 2004, 09:35
yacine
just go to post-processing file/ creat plot and plot it to screen or to a file !
Old   April 23, 2004, 10:01
Julie Polyakh
But I have to get a data first! How do I load the data from the register 4?
Julie
Old   April 26, 2004, 09:14
carno
post processing will automatically (or only) plot from reg 4. Just copy the data to reg 4 which u want to plot and go to create plots in user guide and plot.
plotting field data thomas Siemens 5 November 16, 2006 18:09
Plotting raw data values Wilesco Siemens 0 January 5, 2006 05:34
Psot register data Prabodh Siemens 8 April 23, 2004 01:48
How to get data out from register? leo Siemens 1 May 2, 2003 08:16
Saving graph register data into a file Julie Polyakh Siemens 1 January 27, 2003 21:35
