Home > Forums > CD-adapco
Post Processing
Old   April 27, 2004, 04:34
Default Post Processing
Prabodh
is there any way you can get data at any given location into the post register.
Prabodh
Old   April 27, 2004, 07:55
Default Re: Post Processing
carno
try this... I am not sure whether this works or not. Put cells of interest in cset. Then load pst file. Get required data (getc). plot it.
Old   April 27, 2004, 08:07
Prabodh
Hi Carno! I am not very sure i understand your suggestion. actually i have experimental data at certain points of the domain. i want the data at those points in the post register. Thanks, Prabodh
Old   April 27, 2004, 13:26
steve
If you define sensor points at the locations of the experimental data, you can map the solution to those points. They can be brought into the graph registers but I don't think they can be put into the standard post registers.
Old   April 28, 2004, 00:57
carno
If you want to compare experimental data with your analysis data, why you want to put only that data in post register? 1) You want to put that data in post register means you want to plot it. For that try my earlier suggestion. i.e. Put the cells at your desired locations (where you have experinmental data) in one set(cset). then load the pst file. Then list the post registers and see the results. 2) If you want to just compare the numbers you can moniter the variable(p,T,u,v,w) at selected locations by setwrite command.
Hope I understood your question correctly.
Thanks
Thread Tools
Trackbacks are On
VOF Post-processing...? sushii FLUENT 3 November 20, 2007 06:59
Post Processing in v3.5 Short Phoenics 5 March 16, 2005 05:51
Post Processing D Harvey FLUENT 0 May 24, 2004 21:37
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
Post-processing Eric FLUENT 0 April 19, 2004 10:17
