MIX_FRAC-FUEL_2 in 2-step combustion
Old   April 27, 2004, 13:58
Default MIX_FRAC-FUEL_2 in 2-step combustion
Julie Polyakh
Hi!
I'm working on n-heptane combustion simulation applying the following two reactions:
C7H16 + 7.5O2 -> 7CO + 8H2O
CO + 0.5O2 -> CO2
As you probably know, there are MIX_FRAC-FUEL_1 and MIX_FRAC-FUEL_2 among other species whose oncentrations are calculated. As the rate model I've choosen COMBINED. The problem is that in the converged solution the temperature is very low for stoichiometric combustion (f=0.066) (about 760 K, when I expect it to be above 1200 K) and MIX_FRAC-FUEL_2 equals to zero in all the cells, while CO2 concentration is not zero. What could be the problem?
Regards,
Julie
Old   April 28, 2004, 03:16
Default Re: MIX_FRAC-FUEL_2 in 2-step combustion
Birute
Hello! You can try this option: instead 8H2O write 8H2O[r]. For Mix_frac_fuel_2 can be zero, if you have no CO in incoming fuel. I don't know why, but is not calculating it, it seems that program calls this mixture fractions for all reactions, but calculates it only for incoming fuel components. For interest, you can introduce a little CO in the fuel and it should calculate the mixture fraction. Good luck!
running gambit journal step by step giogio FLUENT 1 March 10, 2008 14:03
time step in unsteady combustion process FRANK LEE FLUENT 2 July 25, 2007 04:51
(step) combustion reactions gosia stein Siemens 3 May 16, 2007 09:49
define moving mesh for engine step by step homan FLUENT 0 October 26, 2005 03:27
premixed combustion step? John FLUENT 0 August 12, 2004 22:03
