April 23, 2004, 02:37 |
Plotting a register data
How do I plot calculated scalar data from register 6, for example? Regards, Julie |
April 23, 2004, 04:28 |
Re: Plotting a register data
In short, you can't: you have to move it to register 4 first (or registers 1,2 and 3 if it is vector data).
You can move data around from one register to another by using the "oper" command. e.g. oper copy 6 4 will copy the information in register 6 to 4. Data in 4 can then be plotted as a contour. You can access the GUI version of this command by going to "Lists > Post Registers ... > Operate ..." |
April 23, 2004, 08:27 |
Ok. And how do I plot it from the register 4?
Julie |
April 23, 2004, 09:35 |
just go to post-processing file/ creat plot and plot it to screen or to a file !
April 23, 2004, 10:01 |
But I have to get a data first! How do I load the data from the register 4?
Julie |
April 26, 2004, 09:14 |
post processing will automatically (or only) plot from reg 4. Just copy the data to reg 4 which u want to plot and go to create plots in user guide and plot.
plotting field data | thomas | Siemens | 5 | November 16, 2006 18:09 |
Plotting raw data values | Wilesco | Siemens | 0 | January 5, 2006 05:34 |
Psot register data | Prabodh | Siemens | 8 | April 23, 2004 01:48 |
How to get data out from register? | leo | Siemens | 1 | May 2, 2003 08:16 |
Saving graph register data into a file | Julie Polyakh | Siemens | 1 | January 27, 2003 21:35 |
