April 28, 2004, 06:01 |
Surface cleanup
I created geometry and meshed(surface)in Gambit and exported the file as geom.neu;I imported the geometry into StarCD using Gambit "geom.neu" and removed all fluis cells using live surf cmmand. when I checked in proam for errors it shows some 42000 multiple edges and zero free edges. Can anybody help me how to remove automatically all the multiple edges?. If not is there any way of importing geometry in to StarCD other than .neu,; Is there any file format which is the most apropriate one for starCd.
thanks James |
April 29, 2004, 03:33 |
Re: Surface cleanup
sorry, but that makes no sense, what you are telling us. when you created a surface mesh in gambit, how can you dele fluid cells in prostar? for live surf command you need fluid cells, shells will then be extracted from then.
I think, you may have double cells - check for them and dele the double cells |
April 30, 2004, 10:32 |
Re: Surface cleanup
prostar can read meshes in any of these formats: patran, nastran, ansys, sdrc, cgns, gambit, and tgrid. Not all information is available in every format, but most translate basic cells and vertices. If the gambit format isn't working, export one of the others and give it a try.
meshing and geometry cleanup _urgent | nag | CFX | 1 | March 16, 2008 16:44 |
Gambit Cleanup | nick | FLUENT | 1 | July 18, 2007 16:17 |
GAMBIT: Hangup on cleanup small face | smillerhh | FLUENT | 0 | October 9, 2006 02:30 |
Surface tension - Continuum Surface Force model | Robert | Main CFD Forum | 0 | May 2, 2002 07:34 |
