-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   time-averaging transient results (http://www.cfd-online.com/Forums/cd-adapco/53787-time-averaging-transient-results.html)
azmir May 8, 2004 01:45
Hello all!
I've been trying to search for a method in Star to time-average transient results for unsteady flows. I went through the archives and still reading after a few hours. Maybe this has been explained before but if you don't mind, kindly tell me how do this time-averaging of transient results this time. Is this available in GUI? If not, do tell.
Jörn Beilke May 8, 2004 15:44
Re: time-averaging transient results
This is an example of prostar macro which I got from Paco who works for the support team in Nürnberg.
The example I was working with had 107 time steps (beginning
from
iteration 2 and increments of 2):
!First loading the pstt file!
trload,druck.pstt,nomvgr,,c
store,iter,2
!We could equally use the command getc, but if one does so,
all the postregisters are cleared.
oper, getc, su, 1
oper, getc, sv, 2
oper, getc, sw, 3
!Postregisters 1 to 3 are devoted to stored velocity
components (in this example). We
!then use postregisters 4 to 6 to store the sum of the
different iterations.
oper, copy, 1, 4
oper, copy, 2, 5
oper, copy, 3, 6
!Here we begin the loop for reading the remaining of
iterations
*define, noexe
*set, increm, 2, 2
store, iter, increm
oper, getc, su, 1
oper, getc, sv, 2
oper, getc, sw, 3
oper, add, 1, 4, 4
oper, add, 2, 5, 5
oper, add, 3, 6, 6
*end
*loop, 1, 107, 1
!In our example the number of time steps stored were 107
oper, sdiv, 107, 4, 4
oper, sdiv, 107, 5, 5
oper, sdiv, 107, 6, 6
oper, inverse, 4, 4
oper, inverse, 5, 5
oper, inverse, 6, 6
azmir May 8, 2004 23:26
Thank you very much for your prompt response. I really needed something like this urgently.
I will modify this macro and inform you of my progress. I suppose the end-product of this macro is one post file? Can I save it with a different name?
steve May 15, 2004 15:03
It may be possible to activate the les averaging option (*.lesc files) for your case. I know you can do this with DES in 315.
I am not sure of the exact process, but I would say
Copy your old problem file
Turn on the les model with averaging and write the problem file (you may get some warnings regarding discretisation etc.).
Check the differences, I suspect one of them will be the flag to activate averaging. You will have to make a edit by hand of the problem file for every case you want to do averaging on.
Try these settings on a small model.
It is worth a try.
Steve
azmir May 18, 2004 01:34
Interesting! Will try! At the moment too much work too little time...
Thanks for the idea!
yacine May 25, 2004 09:09
you can do the avereging in the postdat soubroutine and compute any variable you want!
