Home > Forums > CD-adapco
boundaries
Old   June 8, 2004, 11:11
Default boundaries
Peter
Hello, I am meshing with proam. I am starting with a shell grid including different properties (types). How can I map these properties on the proam volume mesh and change them into boundary conditions. I have seen an option in esuhood- but I don't know how to perform without.
Probably it would be enough to me, to generate a new live surf and change these into boundaries. But how can I do this transfer into a boundary region?
Thanks Peter
Old   June 9, 2004, 16:09
Default Re: boundaries
Jörn Beilke
You should probably run some of the Star-CD tutorials or read the manual how to place boundary regions.
Look at the commands "bfin" , "bcro" and "bzone"
If you have some shells on the surface of the mesh and you want to create a boundary region (z.B. Nr.: 3) from these shells you have to plot the on the screen and do a "bzone 3 all"
Old   June 14, 2004, 02:58
Peter
thank you. But my problem is a bit different: The shells I've used to create my volume mesh are different to the surface of the volume mesh, because I allowed finer grids in Proam. With bzone and bcro it is for different reasons now very uncomfortable to define the boundaries. So I want to map the shells, which I've imported in Proam and which have the zones I am needing as boundaries, on the surface of the volume mesh and define the mapped ones as boundaries.
Old   June 17, 2004, 16:14
sven
Use "bshell".
Thread Tools
Trackbacks are On
UDF and boundaries deneb FLUENT 1 October 24, 2008 03:32
Pro-am boundaries Nalleli CD-adapco 1 July 13, 2005 01:08
Error: Boundaries too far apart Lam FLUENT 0 September 23, 2004 09:08
Help on Filter Boundaries randz Phoenics 1 November 19, 2002 20:44
Particles at boundaries Mark Farrall CFX 1 April 11, 2000 10:02
