Home > Forums > CD-adapco
Train Simulation Entering A tunnel.
Old   June 15, 2004, 20:01
Default Train Simulation Entering A tunnel.
Christos Sfyris
Hi Everybody!
One more time I would like some advice about a problem occured in Star-CD. I have tried to simulate a train entering a tunnel using the Star-CD. Currently there are some problems especially with the creation of the mesh and the simulation of that. I have a couple question if anyone of you might know (Hopefully yes!).
1) Is there any other (easier) way to simulate the train entering a tunnel without having to create "blocks" that will slide relative to each other? Because, it would be easy to do it in a 2D mesh but extremely complicated to perform that in a 3D enviroment.. ( different subroutines, different and more precise meshes)
2) Is it possible to create multiple "static models" ( many different meshes with the train in different positions, just before entering, when it enters and after it has enter) and then compile all the data together to produce an overall result of the simulations? (when the train and the tunnel will be "static" the only parameter that is going to change will be the air flow coming from inside the tunnel in close distance from the front of the train)
Any suggestions, comments or just simple ideas are more than welcome!
Currently I have looked similar cases, but none of them was created (only) in Star-CD. It would be better if I create a 3D simulation rather than a 2D. This would be a MSc disertation and I must use star-cd. If more informations are required (such as blockage ratios or dimensions or speed of the train) are needed please contact me.
Thanks in advance.
Regards
Christos
Old   June 16, 2004, 03:13
Default Re: Train Simulation Entering A tunnel.
F.K.
In reference to your questions
1. No, there isn't another possibility
2. No, you can't use multiple static models. This approach doesn't consider transient effects.
b.g. F.K.
Old   June 16, 2004, 11:12
Birute
At first try to make 2D model. Start with the simplest case to understand how the sliding mesh works. First step - tutorial 11 in STAR-CD. The other cases can help you with some ideas how to set the model, even they are performed using other codes. In this case you will need to make 3D model, because you will have effects on all sides of the train. The final model should be 3D train entering tunel, transient case.
Good luck!
Old   June 16, 2004, 20:26
Christos Sfyris
I have already started building the 2D model in low detail, lets see how this is going to turn up and then i will try the more complicated 3D one..
Thanks for all your help and suggestions! I will post more questions if I have, thanks again!
Regards Christos
Old   June 17, 2004, 05:04
John Luo
There is a way to avoid using cell layer removal and addition. Taking the example of tutorial 11, if you can have very fine mesh at the rear side of train and relative coarse mesh at the front side of train, then when the train moves, you just adjust the mesh by mesh movement.
Old   May 15, 2010, 16:59
Default trains
Antonis Kantas
anty is on a distinguished road
υπαρχει καποιος κυριος να μου πει αν υπαρχει online συστημα για εξομοιωτη τραινων? απαντηστε μου στο mail antoniskantas@otenet.gr
anty is offline   Reply With Quote
Old   January 30, 2012, 01:24
sheikh nasir is on a distinguished road
hi,
i am also trying to apply 2D sliding mesh technique to train moving in tunnel , but not able to do it . can any body help me plz
sheikh nasir is offline   Reply With Quote
Old   February 6, 2012, 07:02
Default sliding mesh
hello , can any body help me in sliding mesh used in train traveling in tunnel. my email is sheikhnasir39@gmail.com
thanks
with regards
Thread Tools
Trackbacks are On
Train Simulation Entering A tunnel Part No 2... Christos Sfyris CD-adapco 2 February 15, 2012 09:59
Help need in modelling train-tunnel interaction xyx FLUENT 1 February 14, 2012 08:29
Effects of a moving train to people in a tunnel J. Kim FLUENT 5 February 14, 2012 08:26
wind tunnel and simulation results different richard FLUENT 2 February 14, 2012 08:06
wind tunnel simulation Andres Paez FLUENT 1 August 15, 2008 00:17
