Call a macro from a macro
Old   June 30, 2004, 12:23
Default Call a macro from a macro
Flav
Hi all, I'd like to know if it is possible to call a macro from another macro. I have the feeling that it stops after executing the second macro...
Thanks in advance
Flav
Old   June 30, 2004, 13:16
Default Re: Call a macro from a macro
4xF
Actually, you cannot call a macro from within a macro . How should a macro know after it's execution it has to come back to the location from where it has been called??? A macro is not a subroutine and does not contain a return statement (I tapped also in this booby trap...) Workaround: write your second macro to a file and use the IFILE command.
Old   July 1, 2004, 05:42
Flav
Working with .inp files seems to be the good option. Thanks a lot for your quick answer !
Regards Flav
what is the macro ? rr FLUENT 0 May 21, 2008 04:43
load sheme macro (Solv Execute Command macro) manu FLUENT 2 March 13, 2008 01:00
Macro Trouble -Winows Explorer Crashes with Macro Martin Castillo FLUENT 1 July 25, 2007 04:18
UDS macro Vidya FLUENT 0 August 9, 2006 22:27
UDF switch macro vs. call Law Christian FLUENT 4 November 24, 2002 01:15
