June 29, 2004, 21:48 |
how to monitor cells-urgent!
Hello!
I want to monitor temperature values at some cells. I suppose I should do this in the tab monitor eng behavior/monitor cell behavior. Then, how do I select entry from a few cells in the cset? Or am I at the wrong tab? |
June 30, 2004, 07:56 |
Re: how to monitor cells-urgent!
Have you tried first to store the cell set using the button INFO -> store set in pro-STAR (please give the set a meaningfull name so that you can remember to what it corresponds easily when you go to the monitoring, not somethin' like zzz or xxx)? For the rest, RTFM.
June 30, 2004, 22:03 |
ok got it!
July 4, 2004, 21:25 |
Help again!
For conjugate heat transfer analysis, I'm monitoring temperature at a few cells in the solid material now. The calculation could not converge and the monitored values keep on decreasing. The monitored graph of temperature vs. iteration is giving negative values (around -22). Are these negative values in Kelvin unit? When I plot the temperature of all the solids at latest iteration though, all the cells are well above 313K. No negative values, so what exactly are the negative values in the graph which I got? |
July 5, 2004, 06:40 |
Because you are looking at the relative temperature of the material, not the absolute!
need paper very urgent humanity,very urgent,urgent | mohamed | FLUENT | 0 | August 9, 2006 11:40 |
URGENT, max number of cells | new-user | Siemens | 3 | August 19, 2004 12:27 |
Shell cells to Fluid cells | Mahbub | Siemens | 1 | October 20, 2003 15:21 |
UDF: neighbour cells, upwind cells | Dmitriy Makarov | FLUENT | 0 | February 18, 2001 13:53 |
Monitor | oliver | FLUENT | 0 | September 5, 2000 15:05 |
