Home > Forums > CD-adapco
reflecting the geometry
Old   July 5, 2004, 13:31
Default reflecting the geometry
isidro
Hi; when you have a simmetry plane on the left hand side of a model, how can you reflect the geometry and the results? The macro on adapco online shows how to do it from left to right (positive z direction) with 'cgen' and then the same thing with 'dgen'. I try changing the the direction for a negative value, that is "CGEN,2,VOFF,CSET,,,VREF,1,3" with "CGEN,-2,VOFF,CSET,,,VREF,1,3", or even tried 1 and 3 but it did'nt work, it seems to be creating a second array of cells in the same location as the original one! Does this mean I have to repeat my geometry? Many thanks. Isidro
Old   July 5, 2004, 14:01
Default Re: reflecting the geometry
4xF
Did you also create a new set of vertices (which will be mirrored with the offset VOFF) *before* using the command CGEN? As you create new cells, you need also to create new vertices...
Thread Tools
Trackbacks are On
TVD non-reflecting boundary shuo Main CFD Forum 1 October 29, 2008 10:06
Non-Reflecting BC(or Absorbing BC) jinwon park Main CFD Forum 3 August 9, 2007 16:30
Non Reflecting B.C. Alshroof CFX 2 July 31, 2007 20:34
Non-Reflecting BC Bounecer Main CFD Forum 1 December 26, 2006 17:52
Reflecting bc kupiainen OpenFOAM Running, Solving & CFD 15 July 13, 2005 08:00
