My patch causes a discontinuity in the mesh
Old   July 6, 2004, 10:11
Default My patch causes a discontinuity in the mesh
Aline
I have a 3D model done with a patch (shells) that I extruded in cylindrical coordinate. I ran the analysis, but I saw in the results that there is a discontinuity in the flow where the patch is, as if the patch was a wall. In the cells list, I have fluid cell except for the patch. What can I do to remove this discontinuity?
Thanks.
Old   July 6, 2004, 11:44
Default Re: My patch causes a discontinuity in the mesh
Brian
Sounds like you extruded to both sides of the patch? (If not, your patch (shells) are against a wall, and there should be a boundary layer)
So after extrusion, did you do a VMERG to link the two meshes together?
Old   July 6, 2004, 11:56
Aline
Thank you! It was that! I did not do the VMERG.
Thanks a lot.
Old   July 6, 2004, 12:00
Aline
But now I have collapsed faces, what can I do?
Old   July 7, 2004, 07:41
Thomas
sounds like you have now some prisms in the center of your duct (due to extrusion and vmerg) put these cells into cset and: cflip cset,,,prism this should work
Old   July 7, 2004, 07:45
Aline
Yes it works. Thanks!
Patch end points mesh motion and movingWallVelocity pbo OpenFOAM Running, Solving & CFD 14 October 4, 2023 11:20
HELP NEEDED HOW TO MAP VALUES FROM PATCH OF ONE MESH TO PATCH OF ANOTHER MESH mkraposhin OpenFOAM Running, Solving & CFD 3 September 4, 2011 09:42
Moving interface patch using mesh subsets lr103476 OpenFOAM Running, Solving & CFD 0 January 10, 2008 16:14
[Technical] Coupled cells or mesh discontinuity sylvain91 OpenFOAM Meshing & Mesh Conversion 0 September 14, 2006 07:43
Patch mesh export ariorus OpenFOAM 3 March 7, 2006 05:41
