Help me-streamlines
Old   July 7, 2004, 10:14
Default Help me-streamlines
Panos
Hi! I am modelling a case of a two dimensional flow over an airfoil and I wanted to know how I can get the streamlines of the flow. I would appreciate your help. Thanks.
Old   July 12, 2004, 05:44
Default Re: Help me-streamlines
Birute
Check tutorial 2 for that. Use the particle tracking option. But, just be sure that you will not have any recirculation, because program will do it until infinity. If you want to have a nice streamlines, use some onother post-processor, if available.
Old   July 12, 2004, 11:06
vladimir
hi panos
in case of your problem is 2D there is an option under "post>load vertex data" menu item which allows you to load streamfunction and display it. You can access it even using the guide (the only way in 3.2 version unless you are interested in the command line).
Old   July 13, 2004, 06:47
Panos
Hi Vladimir The version I am using is 3.15 and I think it is supported right? Agian thanks a lot for your help
StreamLines Rola FLUENT 4 July 6, 2010 11:41
Streamlines yolan CFX 1 August 25, 2006 10:16
streamlines Matthias CFX 3 April 13, 2005 11:52
about the streamlines lingo CFX 5 August 23, 2004 05:07
streamlines ulrich Main CFD Forum 3 September 2, 1999 10:58
