Home > Forums > CD-adapco
prostar/buttons
Old   July 14, 2004, 09:13
Default prostar/buttons
Michiel
In my prostar versions some of the buttons are on the wrong place on the screen. Some of the buttons are not even on the screen. Does anybody have the same experience ? Does that anybody have solution?
Thanks in advance
Michiel
Old   July 14, 2004, 10:52
Default Re: prostar/buttons
yacine
I noticed the same problem in Linux and with the version 3.15 and above. the solution is to make the window bigger with the mouse go to an other file in the guide window then go back then you should be aible to see the buttons !!!
Old   July 14, 2004, 11:00
Michiel
Hi Yacine,
That's what I found out to but it's not always solving the problems. in 3.2 the problem has become worse.
Michiel
Old   July 14, 2004, 13:50
Jörn Beilke
A screen resolution of 1280x1024 is required for prostar.
Old   July 15, 2004, 02:50
Michiel
Changing the resolution has no effect. The problems are still the same.
Old   July 15, 2004, 03:09
Stefan Hildenbrand
Maybe I'm not getting the problem correctly, but I had similar problems which then were resolved by introducing
Option "BackingStore" "On"
into the "Screen" Section in /etc/XF86Config
Old   July 15, 2004, 04:48
Ulf
Hi Michiel, I have the same problem as you with 3.20. It is quite annoying. I hope someone here has the solution for us. Regards Ulf
Old   July 15, 2004, 07:48
Michiel
Good suggestion tried it but it Didn't solve the problem
thanks for the advice
Old   July 15, 2004, 09:01
Default Re: prostar/buttons --> solution
Michiel
Contact with CD-adapco gave the following working solution( for my suse linux)
downgrade to openmotif 2.1
/usr/X11R6/lib/libXm.so.2.1
for Red-had install
rpm -i --force --nodeps openmotif-2.1.30-4_MLI.i386.rpm \
openmotif-devel-2.1.30-4_MLI.i386.rpm
cheers
Thread Tools
Trackbacks are On
Prostar "cutie" ? field function CD-adapco 0 December 2, 2007 15:43
Prostar doesn't starts Ruggero CD-adapco 2 July 8, 2007 16:53
prostar Error Pialisen CD-adapco 2 September 9, 2006 14:06
PROSTAR Emmanuel Resch CD-adapco 7 August 1, 2006 08:37
where can i buy Prostar starCD Abdi Main CFD Forum 1 October 22, 2002 18:00
