STAR-CD cannot run normally.
Old   July 20, 2004, 09:05
Default STAR-CD cannot run normally.
xhliu1
When I run my STAR-CD software from star launch,I can not run it normally,but there are some error massage as -------------------------------------------------------
******PROSTAR VERSION 3.103.519******
PRE/POST PROCESSOR FOR STAR-CD Licensing problem: Unable to list licensed features Cannot connect to license server The server (lmgrd) has not been started yet, or the wrong port@host or license file is being used, or the port or hostname in the license file has been changed. Server name: ndt License path: d:/PROGRA~1/STAR-CD/v3150A/license/license.dat FLEXlm error: -15,10. System Error: 10061 "WinSock: Connection refused" For further information, refer to the FLEXlm End User Manual, available at "www.globetrotter.com". Çë°´ÈÎÒâ¼ü¼ÌÐø . . . -------------------------------------------------------
To run my STAR-CD normally,what should I do?
Old   July 20, 2004, 12:19
Default Re: STAR-CD cannot run normally.
Pauli
The message is telling you that prostar can not get a valid license.
You need to fix your license problem.
Old   July 21, 2004, 09:29
xhliu1
Thank you very much,Mr./Miss Pauli! But I have not solver the problem,can you tell me what I should do detailly?
Out of that problem,I have another problem: When I run my STAR-CD in the linux system atfer linking,the are some information,but I can not run my star.
License info: CDLMD_LICENSE_FILE=/opt/v3100B/license/license.dat (from~/.flexlmrc)
Checking out starsolver
***GEOMETRICAL CALCULATIONS STARTED
***GEOMETRICAL CALCULATIONS COMPLETED
?FORTRAN Runtime Error:
?Attempt to read past end of file
?Read(UNIT=9,...)
Old   July 21, 2004, 09:37
Brian
Unit 9 is the post file - this means you are trying perhaps to restart from a post file that does not exist, or contain the information required for a restart.
Old   August 1, 2004, 08:50
Default Can not run CD
Zahid
Hi, I want to ask you that when I insert a CD in my computer its can not run. It shows "ERROR, can not run setup". I dont know that what the problem is with my computer. I hope you'll help us!
how to export a mesh from star design to star cd aounallah Siemens 4 March 6, 2009 06:22
Star Design to Star-CD(Prostar) AB Siemens 5 October 28, 2004 12:21
