Lack of convergence
Old   July 21, 2004, 10:25
Default Lack of convergence
Scott
I was wondering what of the many things can cause a solution to not converge. The only problem that exists within my mesh is internal angles being too large or too small. Is it then a case of these internal angles, or does it have to do with the boundary consitions? My mesh is not very uniform either - it was created from some connecting blocks, which have various grid densities to account for geometry - could this be the cause? Sorry for the long message.
Old   July 21, 2004, 11:49
Default Re: Lack of convergence
Panos
The general situation of the mesh is always a very immportant factor of divergence in CFD. There are additional reasons but in your case I think it's the mesh. What equations exactly are you solving and what relaxation factors are you using?
Old   July 23, 2004, 00:25
wak
Heloo,
I'm also have the same prob with that,block meshing..i using UD equation n than restart with MARS after several iteration to stabilize it.
Cracks and couple may also cause it.
URF and convergence in natural convergence Marie-Anne Main CFD Forum 11 September 11, 2009 10:07
WSS lack of convergence longchuan FLUENT 0 July 31, 2008 21:58
Heat Exchanger Fluids Lack Temperature Difference justinF FLUENT 2 July 11, 2007 22:55
lack of support for VOF in version 3.26 Tom Siemens 10 August 6, 2006 08:20
Heat balances .... or lack of Jason Norman FLUENT 12 April 20, 2000 03:30
