Home > Forums > CD-adapco
Density out of bound
Old   July 22, 2004, 07:40
Default Density out of bound
Prashant Khare
can some one help me? I am solving a turbomachinary problem with compressible flow..density as a function of pressure and temprature.There is a warning in info file that density is out of bound due to pressure correction at cell.. limiter applied. please i am not able to understand what should i have to do. Thanks in advance for any help
Old   July 22, 2004, 08:15
Default Re: Density out of bound
Sébastien ERNANDES
Everyone has already had this warning....... I'm a novice as StarCD user, but I propose to you : - try to decrease your time step (have a look about 'Courant Number' in the user guide). - try to launch your run in double precision. - verify your molecular properties (Density : ideal f(T,P) / Viscosity : Multicomp. / Specific Heat : Polynomial / Conductivity : Multicomp. ).
Maybe decrease some relaxation factors could be helpful, but I'm not sure...
Good luck.
Old   July 22, 2004, 08:23
Prashant Khare
Thank you for your reply but i am solving a steady state flow and i am also using low pressure relaxation factor(0.03).Can any other reasons possible?
Old   August 1, 2004, 22:35
xhliu1
You can try transient solving. Good wishes!
Thread Tools
Trackbacks are On
Create an upper bound daniel_mills OpenFOAM Running, Solving & CFD 0 October 20, 2006 18:34
*** WARNING #060 *** DENSITY OUT OF BOUND DUE T varun CD-adapco 0 March 25, 2005 17:19
Bound node loop. Jack Keays FLUENT 5 July 9, 2000 13:57
Low Re k-e model bound. conds Abhijit Tilak Main CFD Forum 1 October 7, 1999 05:31
Compressible N-S bound. condn. Kuttoosan Main CFD Forum 1 July 6, 1999 12:46
