WARNING #052
Old   July 22, 2004, 09:29
Default WARNING #052
Aline
In the info file, I have this error: WARNING #052 *** INITIAL RESIDUAL BELOW ROUND-OFF ERROR LIMIT SOLUTION ,EQ: SC1
What does that mean? Is it important? If it is, what can I do?
Thanks
Aline
Old   July 23, 2004, 03:25
Default Re: WARNING #052
Richard
The error means that the solver has found that the residual in the scalar 1 linearised equation is roughly zero (i.e. less than the round-off limit). Usually this isn't bad news: it just means that the scalar has already converged so the solver need not do any more work on it. If you hadn't expected the scalar to converge though, maybe this is something to worry about.
Old   July 23, 2004, 08:47
Aline
Thanks Richard, so I think it is not bad news because the results are quite good.
Warning 046, what does it mean? SAKTI Siemens 1 July 31, 2008 12:14
warning #064 ema Siemens 1 August 25, 2005 05:45
warning # 90 vishal Siemens 1 August 11, 2005 09:19
*** WARNING #052 *** Cirilo Siemens 1 July 27, 2005 08:34
Warning Paco Siemens 0 June 23, 2005 02:33
