Home > Forums > CD-adapco
How to start background job ?
Old   August 13, 2004, 09:11
Default How to start background job ?
Piet
Could someone tell how I can start a background job in star 3.2.?? The job is always stopped when I close the shell!
thx
Old   August 13, 2004, 09:30
Default Re: How to start background job ?
a.
it should be star -batch
Old   August 13, 2004, 10:07
Piet
thx
but it doesn't work for multiple nodes! I need the batch comand for
star node1,1 node 2,1 node3,1 etc..
Old   August 13, 2004, 11:23
Jörn Beilke
nohup star node1,1 node 2,1 node3,1 etc.. > star.log &
Old   August 13, 2004, 11:27
user
I am having the same problem. Nohup does not help either.
Old   August 13, 2004, 19:59
robbie
You can use "screen" a Linux's command. It can run a job in the background.
Old   August 16, 2004, 03:26
Piet
Thanks for your attempt but it doesn't work on Redhat.
I guess CD has forgotten to install a batch job !!
Old   August 21, 2004, 04:35
kris
Hi.. Linux background command is as following
first, excute your 'star'. if so, monitoring calculation result is about each iteration on the console screen.
second, Press ctrl+z.
third, Press "# jobs" #=>shell
forth, bg %1 => if the number of 1 is job of STAR...
It may be possible to be made backgroud job on your Linux machine...
Acutally I don't know whether it is yours which is answer you want because of no test.
Confirm your test.
Thread Tools
Trackbacks are On
How to run CFX on the background? David CFX 1 January 19, 2004 17:24
Display background XCL FLUENT 4 November 12, 2002 20:18
how to run fluent 5.4 in background l.g.patil FLUENT 5 February 1, 2002 13:06
background color Nurul Murad FLUENT 2 August 30, 2001 01:45
Unsteady Background Job ? Prateep Chatterjee FLUENT 1 July 13, 2000 13:57
