Moving Mesh Problem in Unix Platform
Hello All,
I tried to solve moving mesh problems using windows but due to compiler problems..ie I need to buy fortran compiler ..so I shifted to UNIX version and started solving tutorial 11 of moving mesh and I have some problems associated with it. I am using version 3.2 The problems are:: 1. The program is not running. I created the model as instructed in the tutorial and even the geometry file and problem file is created properly. but when i go to the mail terminal to run the pmovlink script.. the command 'pmovlink ' gives me an error saying bad command name. 2. Also when i run the model without it, I get the following error message:: **NORMAL TERMINATION** mesolv% star tee: /users/abanerje/2004/Tut/star.msg: No such file or directory PNP: Initialized [2004-08-14-14:13:53] Automatic Sequential Automatic Parallel analyzer. tee: /users/abanerje/2004/Tut/star.msg: No such file or directory PNP: Allocated "mesolv,1" resource (1 process). tee: /users/abanerje/2004/Tut/star.msg: No such file or directory PNP: Overload STAR master processor with external moving mesh code. tee: /users/abanerje/2004/Tut/star.msg: No such file or directory PNP: Assigned "mesolv,1" to STAR solver (1 process). tee: /users/abanerje/2004/Tut/star.msg: No such file or directory PNP: Assigned "mesolv,1" to external moving mesh code (1 process). tee: /users/abanerje/2004/Tut/star.msg: No such file or directory PNP: Analyzing User coding in "ufile" directory. tee: /users/abanerje/2004/Tut/star.msg: No such file or directory PNP: compiling f90 -w -fast -xarch=v9b -c uparm.f -o sunos64_5.8-ultra3-f90_7.0-dso/uparm.o /opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/bin/star: f90: not found tee: /users/abanerje/2004/Tut/star.msg: No such file or directory PNP: ***ERROR*** Compilation error in user file "ufile/uparm.f". tee: /users/abanerje/2004/Tut/star.msg: No such file or directory PNP: ==> Please check the compilation error messages. mesolv% Could you tell me where my problem is? If someone wants me to send the files...cgrid.cgrd and uparm.f.new then i can send it so that someone can clear my doubts. UPARM FILE::: C************************************************* ********************** SUBROUTINE UPARM(VCORN,A,I) C User-coded EGRID parameters C************************************************* ********************** C----------------------------------------------------------------------* C STAR VERSION 3.20.000 * C----------------------------------------------------------------------* INCLUDE 'comdb.inc' COMMON/USR001/INTFLG(100) DIMENSION A(0:999),I(0:999) DIMENSION VCORN(3,NDMAXU) INCLUDE 'usrdat.inc' C----------------------------------------------------------------------- C C This subroutine enables the user to define parameters to be used C by pro-STAR when it is called during the execution of EGRID C in a moving mesh simulation. C C ** Parameters to be returned to STAR: A,I C C----------------------------------------------------- ------------------ NDOM=0 DC 10 IC=14,602,14 CISTAT= 0 => DELETED CISTAT= -1 => MARKED FOR DELETION CISTAT=- 2 => NO SUCH FLUID CELL (may BE SOLID, BAFFLE,SHELL ETC) CISTAT= 1 => LIVE CELL CALL LIVCLL(IC,ISTAT) IF(ISTAT.EQ.1) NDOM=NDOM+1 10 CONTINUE C I(0) = NDOM NUP = 0 DO 20 IC=2473,3061,14 CALL LIVCLL(IC,STAT) IF(ISTAT.EQ.1) NUP=NUP+1 20 CONTINUE I(1) = NUP A(0)=DT C Sample coding: To specify a piston position and number of cells C Suppose there are 10 cells initially, and one cell is removed at C each event from the bottom. C C The EGRID commands in pro-STAR will be C *SET,NCLL,I000 C *SET NCDL 10 - NCLL C *SET,PPOS,A000 C VSET NEWS VRANGE 1 NCDL * 10 + 1 C VMOD VSET,,,PPOS C VFILL NCDL * 10 + 1,101,NCLL,NCDL * 10 + 11,10,4,1 C C The corresponding coding in UPARM for I000 and A000 will be C C PI=3.14159265 C C=40.0 C A1=9.0 C OMEGA=100. C ZREF=1. C THETA=PI*OMEGA/30.*TIME C A(0)=A1*(1.-COS(THETA))-C+SQRT(C**2-A1**2*(SIN (THETA)**2)) C I(0)=IEVNO C----------------------------------------------------- ------------------ RETURN END C |
Re: Moving Mesh Problem in Unix Platform
If usercoding is used the Fortran Compiler Absoft must be installed on Windows Linux AND Unix plattforms. Why do think a Fortran compiler is not necessary on UNIX plattforms?
Hello All,
I ran another simple program and it gave me no errors in writing geometry file nor in problem file but when i start to run the analysis interactively, I came across with the below error.. Can someone tell me if there is a common connection between both the simulations... the one i wrote before(1st message) and the one now. Is both have errors in running due to any missing link or compiler or something??? Shared library path is .:/opt/starcd/PROSTAR/3.20.01/sunos64_5.8-ultra/lib64/prostar:/opt/starcd/RUNTIM E/1.2.0/sunos64_5.8-ultra2/lib:/opt/starcd/PROSTAR/3.20.01/sunos64_5.8-ultra/lib 64: ****** pro-STAR VERSION 3.20.001 ****** PRE/POST PROCESSOR FOR STAR-CD BUILD DATE=MAR-17-2004 PROSTAR = /opt/starcd/PROSTAR/3.20.01/sunos64_5.8-ultra/ STARDIR = /opt/starcd/ STAR = /opt/starcd/STAR/3.20.000/sunos64_5.8- ultra3-f90_7.0-dso/ STARUSR = ./ Checking license file: /opt/FLEXLM/9.0.0/sunos_5.8-com/bin/license.dat Checking license file: /opt/starcd/license/license.dat 1 copies of starsuite checked out from /opt/FLEXLM/9.0.0/sunos_5.8-com/bin/licen se.dat all other features can only be checked out from same server Feature starsuite expires in 319 days Using a 24 bit TrueColor visual (visual id: 0x27). RUNNING CASENAME: twod ./star_inter.sh: ~/envdump: cannot create /opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/bin/starwdaemon: syntax error at line 1: `(' unexpected PNP: Initialized [2004-08-15-15:38:29] Automatic Sequential Automatic Parallel a nalyzer. PNP: Allocated "mesolv,1" resource (1 process). PNP: Assigned "mesolv,1" to STAR solver (1 process). PNP: Loading STAR solver dynamic shared object plug-ins. PNP: Starting TRACKER task on "mesolv" for monitoring host and process failur es. PNP: Spawning STAR process on single node. /opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/lib/star: ^?ELF^B^B^A^B +^A^A^A?\200@^NÈ^X: not found /opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/lib/star: @8^E@^Z^X^F^E @^A@^A^X^A^X^C^D^AX^Y^A^E^A: not found /opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/lib/star: ë\202: not fo und /opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/lib/star: ë\202^P^A^G: not found /opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/lib/star: ë\210^A^Zë\21 0y÷^A+l^P^B^G: not found /opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/lib/star: øè^A^Zøè^C°/u sr/lib/sparcv9/ld.so.1^Eó^Eí^C^G^H: not found /opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/lib/star: syntax error at line 8: `(' unexpected PNP: Shutdown [2004-08-15-15:38:31] Execution aborted by request (SIGABRT) af ter 2 seconds (TOTAL ELAPSED TIME). |
In 3.2, one should type mvgrid,on,PROSTAR instead of mvgrid,one alone as in 3.15 (told from technical support)
