What is this Error & how to rectify??
Old   August 23, 2004, 16:01
Default What is this Error & how to rectify??
Arnab
I am getting this error message whenever I try to run some simulation on star-CD.. either a tutorial or any simple model. I am using the new version of star-CD V 3.2 and I dont know how to get rid of this error message and get my simulation running??
The Error Message is as follows:
****** pro-STAR VERSION 3.20.001 ******
PRE/POST PROCESSOR FOR STAR-CD
BUILD DATE=MAR-17-2004
PROSTAR = /opt/starcd/PROSTAR/3.20.01/sunos64_5.8-ultra/
STARDIR = /opt/starcd/
STAR = /opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/
STARUSR = ./
Checking license file: /opt/FLEXLM/9.0.0/sunos_5.8-com/bin/license.dat
Checking license file: NOLICENSE
Checking license file: /opt/starcd/license/license.dat
1 copies of starsuite checked out from /opt/FLEXLM/9.0.0/sunos_5.8-com/bin/licen se.dat
all other features can only be checked out from same server
Feature starsuite expires in 314 days
Using a 24 bit TrueColor visual (visual id: 0x27).
RUNNING CASENAME: 1000
./star_inter.sh: ~/envdump: cannot create
/opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/bin/starwdaemon: syntax error at line 1: `(' unexpected
tee: /users/abanerje/2003/time/star.msg: No such file or directory
PNP: Initialized [2004-08-20-12:07:30] Automatic Sequential Automatic Parallel a nalyzer.
PNP: Allocated "mesolv,1" resource (1 process). tee: /users/abanerje/2003/time/star.msg: No such file or directory
PNP: Assigned "mesolv,1" to STAR solver (1 process).
PNP: Analyzing User coding in "ufile" directory.
PNP: compiling f90 -w -fast -xarch=v9b -c initfi.f -o sunos64_5.8-ultra3-f90_7 .0-dso/initfi.o
/opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/bin/star: f90: not foun d
PNP: ***ERROR*** Compilation error in user file "ufile/initfi.f".
PNP: ==> Please check the compilation error messages.
**WARNING - the starwatch server daemon is not registered.
**WARNING - Using default port 6200
The starwatch server daemon is not running.
Old   August 24, 2004, 03:15
Default Re: What is this Error & how to rectify??
F.K.
It seems to me that a defective subroutine is used due to "PNP: ***ERROR*** Compilation error in user file "ufile/initfi.f""
Check your model
Old   August 24, 2004, 04:20
alex
The reason it fails to compile the user coding is because it cannot find your fortran compiler: "/opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/bin/star: f90: not found"
You can fix this in your hardware.ini (in $STARDIR/etc). There may be a specific variable (e.g. for Linux you specify ABSOFT), but if not, there will be a line that looks like this: "platform SunOS_UltraSPARC PATH=" which specifies your path. Put the actual location of your f90 compiler here and it will work.
Errors when Compiling UDF: error C2040/error C2099 Julian K. FLUENT 1 December 21, 2008 00:23
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
How to rectify it 21kalee OpenFOAM Installation 0 October 17, 2007 01:29
How to rectify dis ?? shriram FLUENT 0 July 1, 2007 10:27
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 08:48
