August 23, 2004, 16:01 |
What is this Error & how to rectify??
I am getting this error message whenever I try to run some simulation on star-CD.. either a tutorial or any simple model. I am using the new version of star-CD V 3.2 and I dont know how to get rid of this error message and get my simulation running?? The Error Message is as follows: ****** pro-STAR VERSION 3.20.001 ****** PRE/POST PROCESSOR FOR STAR-CD BUILD DATE=MAR-17-2004 PROSTAR = /opt/starcd/PROSTAR/3.20.01/sunos64_5.8-ultra/ STARDIR = /opt/starcd/ STAR = /opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/ STARUSR = ./ Checking license file: /opt/FLEXLM/9.0.0/sunos_5.8-com/bin/license.dat Checking license file: NOLICENSE Checking license file: /opt/starcd/license/license.dat 1 copies of starsuite checked out from /opt/FLEXLM/9.0.0/sunos_5.8-com/bin/licen se.dat all other features can only be checked out from same server Feature starsuite expires in 314 days Using a 24 bit TrueColor visual (visual id: 0x27). RUNNING CASENAME: 1000 ./star_inter.sh: ~/envdump: cannot create /opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/bin/starwdaemon: syntax error at line 1: `(' unexpected tee: /users/abanerje/2003/time/star.msg: No such file or directory PNP: Initialized [2004-08-20-12:07:30] Automatic Sequential Automatic Parallel a nalyzer. tee: /users/abanerje/2003/time/star.msg: No such file or directory PNP: Allocated "mesolv,1" resource (1 process). tee: /users/abanerje/2003/time/star.msg: No such file or directory PNP: Assigned "mesolv,1" to STAR solver (1 process). tee: /users/abanerje/2003/time/star.msg: No such file or directory PNP: Analyzing User coding in "ufile" directory. tee: /users/abanerje/2003/time/star.msg: No such file or directory PNP: compiling f90 -w -fast -xarch=v9b -c initfi.f -o sunos64_5.8-ultra3-f90_7 .0-dso/initfi.o /opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/bin/star: f90: not foun d tee: /users/abanerje/2003/time/star.msg: No such file or directory PNP: ***ERROR*** Compilation error in user file "ufile/initfi.f". tee: /users/abanerje/2003/time/star.msg: No such file or directory PNP: ==> Please check the compilation error messages. **WARNING - the starwatch server daemon is not registered. **WARNING - Using default port 6200 The starwatch server daemon is not running. |
August 24, 2004, 03:15 |
Re: What is this Error & how to rectify??
It seems to me that a defective subroutine is used due to "PNP: ***ERROR*** Compilation error in user file "ufile/initfi.f""
Check your model |
August 24, 2004, 04:20 |
The reason it fails to compile the user coding is because it cannot find your fortran compiler: "/opt/starcd/STAR/3.20.000/sunos64_5.8-ultra3-f90_7.0-dso/bin/star: f90: not found"
You can fix this in your hardware.ini (in $STARDIR/etc). There may be a specific variable (e.g. for Linux you specify ABSOFT), but if not, there will be a line that looks like this: "platform SunOS_UltraSPARC PATH=" which specifies your path. Put the actual location of your f90 compiler here and it will work. |
Errors when Compiling UDF: error C2040/error C2099 | Julian K. | FLUENT | 1 | December 21, 2008 00:23 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
How to rectify it | 21kalee | OpenFOAM Installation | 0 | October 17, 2007 01:29 |
How to rectify dis ?? | shriram | FLUENT | 0 | July 1, 2007 10:27 |
Fatal error error writing to tmp No space left on device | maka | OpenFOAM Installation | 2 | April 3, 2006 08:48 |
